Skip to Main Content
IBM Data Platform Ideas Portal for Customers
This portal is to open public enhancement requests against products and services offered by the IBM Data Platform organization. To view all of your ideas submitted to IBM, create and manage groups of Ideas, or create an idea explicitly set to be either visible by all (public) or visible only to you and IBM (private), use the IBM Unified Ideas Portal (https://ideas.ibm.com).
Shape the future of IBM!
Search existing ideas
Post your ideas
Post ideas and requests to enhance a product or service. Take a look at ideas others have posted and upvote them if they matter to you,
  1. Post an idea
  2. Upvote ideas that matter most to you
  3. Get feedback from the IBM team to refine your idea
IBM Employees should enter Ideas at https://ideas.ibm.com
Status Not under consideration
Workspace SPSS Modeler
Created by Guest
Created on May 4, 2018
Extension Node - Syntax Highlighting
Initial Situation: In same cases we have the need in ibm spss modeler streams to use R / python to add very special functionality.
Issue: The extension node, e.g. (extension model) has no syntax highlighting
Due to the lack of usability, most of internal customers jump for example to R - Studio, Jupyter  and then copy and paste code to ibm spss.
Benefit: Increase of developer efficiency
number of users affected: ~10
  • Guest
    Oct 10, 2020
    This is a great suggestion, thank you. We will likely implement first on the SPSS Modeler on Cloud version within Watson Studio and Cloud Pak for Data.
